OK, firstly we need to break this down, with such a complicated question as this one......from the beginning........When you added the 2 6x9 and a n amp, how do you have this wired up with the original set up of 6.5's and 5x7's.........were they added or did you fit them in place of these ones...????
So you wanna run the subs off of the rear pre amp output rather than just the sub out correct? just get a splitter and run both the rear speakers and sub off of rear channel and front off of front channel. or run all four off of front and subs off rear output. this should give you the sound you want
there isn't a separate sub pre amp, there are three sets - front/high, rear/mid and sub/non-fade.
I need to know how to get highs to both tweeters and mid or lows to the woofers in the back doors (3 way component) and highs to the tweeters and mid or lows to the woofers in the front doors (two way component). Or, how to get full range to all speakers to utilize the passive crossovers. It's all Eclipse, so i figure they designed the speakers to work with the head unit, and being good quality i doubt they would limit the options on the pre amps.
