Rotel RX-965 Receiver Logo
Posted on Nov 04, 2010
Rsx 965 remote code - Rotel RX-965 Receiver
Why my URC SL-9000 can not control ROTEL RSX-1056 AV Reveiver
Do an auto search method to search for codes. If the remote control have set-up code to your device, you will win. If not, buy an other remote control, which have set-up code/s to your device brand.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Where can we buy the remote of RSX 1067 7IN1
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Hi i have a Rotel Rsx 1067, powers up then off, the remote control is using new batteries, the receiver pickups the remote sensor but doesn't do nothing. volume control does not adjust up or down, and when...
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
Hughes remote codes
The only model of remote that i heard that it has pre-program Olevia code in it.. is the RC-64 or RC-64RB usually these remotes are coming with the new HD boxes..
Direct TV
Remote Codes 506 or 127
Direct TV (Remote Model RC-64RB)
Remote Codes 11144, 11240, 11331, or 11610
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available… please call at 866-965-3842
2answers
My Rotel RSX-972 surround sound receiver has no power, the repair centre cannot isolate the problem and they do not have a service manual to guide them,a service manual would be handy??
Unless yuo can find a Rotel authorized service center, you are not likely to find any service information. These units should not be difficult to repair. Their designs are pretty much standard with a few twists. Any shop that handles audio repair should be able to resolve this. If not, please post your location and I'll try to locate a shop for you.
Also, are there any indications that the unit is trying to work at all or is it completely dead?
Thanks,
Dan
2answers
Need a code for my 02 Acura Rsx type S
I had the saem problem, you should have a code that came with the manual its on a card and it will give you the password. If you dont have one take it to a honda/acura dealership
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Larry
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
