I am not sure how to connect my bluetooth model vbt185z
My bluetooth cannot connect to my phone-i try to connect it and it keeps saying connection failed.
I have a Motorola Krazor, and a Jabra ear set. I cannot connect the bluetooth. I'm having problems. Can anyone help me/I have a Motorola Krazor, and a Jabra ear set. I cannot connect the bluetooth. I'm having problems. Can anyone help me/
You can't post conmments that contain an email address.
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step. http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Turn on paring by pressing and holding center (blue button) until LED is solid blue. Headset goes into pairing mode (unless already paired). Set your phone t "discover Jabra VBT185Z." Enter PIN, "0000"
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
I have a motorola RAZR V3m and my new Jabra VBT185Z does not seem to be discoverable by my phone. How do I connect??
