Microsoft Xbox 360 Elite Console Logo
Posted on Jul 16, 2017
Just bought xbox live gold prescription. With orange broadband, as i understand the console has wireless network connection. Following the instructions on the console on how to set up xbox live,we are not sure what the ssid of the desired network is, and which of the edit wireless security settings is. As we are not sure of the technical jargon with computers, please could you expain what we have to do in simpler terms.
5 Related Answers
Anonymous
  • Posted on Sep 26, 2007
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
Anonymous
  • 4402 Answers
  • Posted on Dec 08, 2007
SOURCE: NetComm NP285 xbox compatibility?
when I go to network settings-->advanced--> wireless, it tells me that the wireless adapter was not detected.
Where are you getting this message from?
A
Anonymous
  • Posted on Dec 31, 2007
SOURCE: wireless xbox connection
Make sure you have the X-Box Adapter on the same channel as the wireless access point...If your WAP is not broadcasting the SSID then you will have to manually put it in...
Anonymous
  • Posted on Nov 07, 2008
SOURCE: cant connect to xbox live through router
my xbox360 does not want to connect to wireless connection,it's been two days now..
Anonymous
  • Posted on Feb 14, 2009
SOURCE: cant connect to xbox live with vzaccess!! please help...
You have two options. Number 1, plug the 360 into a LAN port on your PC and set up the LAN connection to share the internet with the VZaccess connection. This will work as long as you are connected through vzacess manager.
Option number two, get an EV-DO router, wireless or wired, and use it to connect the xbox.
If using option 1, you may have to struggle at first with the IP settings. Make sure the LAN connection AND the 360 are set up to configure IP and DNS automatically. And make sure that you set the sharing options to include http and such. more help can be found by searching in Windows Help for ICS (internet connection sharing)
1helpful
2answers
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
4helpful
How to get an internet connection for xbox live
Hello award ward,
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible
with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
michael34
1helpful
2answers
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
4helpful
3answers
Xbox 360 wireless adapter doesnt work the light on the back just stays red and i dont get how to make it work
Hi. You just need to configure your adapter. It is not broken, it just needs to be set up properly. For information on how to do this, please see: http://support.microsoft.com/kb/908877
I just bought this router and am trying to get it connect with a Verison wirelss USB mobile broadband. How can I connect it to my computer and an Xbox 360?
For Verizon i found that Currently, the DIR-412 Mobile Broadband Wireless Router is the only D-Link router that is 3G compatible. The DIR-412 supports 3G USB adapters complying with HSUPA/HSDPA/EV-DO/TD-SCDMA networks and works with most major cellular carriers (AT&T, Sprint, Verizon, Rogers, Telus, Bell, etc).
D-Link routers empower gamers to easily connect their Microsoft Xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and Xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft Xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to Xbox Live.
  • Click here to upgrade your firmware.
  • Click here for Xbox Live setup instructions with a router.
  • For Xbox Live support, please visit www.xbox.com.
  • If you need more help come back.
    Post / thumbs / testimonial are welcome!
    I cant get on x box live
    ok well ill giv u a check list on how to do it 1 hav a broadband connection 2 connect an ethernet cable to your modem from your xbox 3 u are now connected to the internet so either buy a reedeemable xbox live gold card from the store or enter credet card info and use xbox's direct buy for ur gold membership
    5helpful
    5answers
    Xbox live connection
    three is the network
    connect and install three usb modem
    connect xbox to pc with ethernet cable
    then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
    now connect 3 3g device turn on xbox and BINGO !
    Top Microsoft Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ELECTRICKSUSA
    ELECTRICKSUSA
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
