Question about Onkyo TX-SR605 Receiver
Hooking up my Wii
Hi there, I am having trouble hooking my Wii up to my Onkyo receiver. It is all hooked up to the tv using HDMI cables. After trying to hook it up using the standard A/V (red, white and yellow) cables, I thought perhaps that was the problem and went out and bought Component cables hoping that would solve the problem, but no such luck...I know I am being pretty vague, but any help would be wonderful. Thank you.
SOURCE:
  • 14 Answers
SOURCE: Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Posted on Dec 13, 2007
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
tech240
  • 169 Answers
SOURCE: hooking laptop to onkyo sr604 through hdmi no
hdmi is video only
you will need to use the rca/phono inputs for audio.
you will need a stereo mini jack to steroe rca/phono
use the i/p marked aux/cd/
make sure the volume on the onkyo is turned DOWN before connecting any new input source.
The output from most laptops is designed for headphones so you may need to adjust the volume on the laptop DOWN as well.
Perhaps start off with laptop at 30% and the amp DOWN then increase the amp until you can hear the laptop sound.
To get good quality audio from a laptop you would be beter off with a USB sound card.
hope this helps, thanks for using FixYa
if this is helping please vote.
Posted on Feb 20, 2010
  • 7 Answers
SOURCE: I have a Onkyo TX-SR806 HDMI output does not work
Sounds like you may have a bad HDMI card my friend. I had an issue with my HDMI card that was causing blue dots to appear on the dark parts of the screen, when outputting 1080p over HDMI. This is a rather common issue, so it wouldn't surprise me if your HDMI board needs replacement - especially if you've ever experienced the infamous blue dot issue.
Posted on Mar 04, 2010
  • 137 Answers
SOURCE: Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Posted on Apr 19, 2010
My wii is connected through component cables and runs to tv HDMI
In the receiver's main menu or setup on the remote you will find "input/output assign", make sure the "HDMI Monitor" is set to "yes".
This will make sure whatever video source is connected will be upconverted and outputted to the HDMI going to your TV. If it is set to "no" it will not show your Wii.
May 24, 2010 | Onkyo TX-SR605 Receiver
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Apr 19, 2010 | Onkyo TX-SR606 Receiver
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
How do you hook up the wii to the HItachi UT 42 x 902?
Problem: Hooking up Hitachi UT42X902 to a Wii
Solution: Even few technicans understand the issue because they have a hard time comprehending the Hitachi UT42X902 Director Series only has 1 HDMI jack and no RCA connections. I have both a Wii and UT42X902. At one point when I had a 4-way call with Hitachi, Nintendo, and Onkyo trying to figure this all out. So after several miss-steps, here is what I did and it worked…
I ended up buying an Onkyo TX-SR606 AV Receiver Amplifier-Tuner which has "uplink" capability. (Do not buy the TX-SR506 or other Onkyo models they do not have the right uplink capability to work the Wii on the UT42X902 Director Series, I already made that mistake and the store would not take the 506 back by the time I got everything I needed to connect the system.) I then bought a off Nintendo market Red/White/Blue/Green/Yellow HD or HDMI compatible (for the Onkyo side) on one end and Wii compatible on the other (sorry I don’t remember the technical name for the cable but they are pretty common and Best Buy and other electronics stores have it). I connected the cable to my Wii and the 5 ended side of the cable to the Onkyo. My CATV satellite box and DVD player are also connected to the Onkyo with Monster 1000HD (10.5 Mbps) HDMI cables. The Onkyo is connected to the Hitachi UT42X902 also via a Monster 1000HD (10.5 Mbps) HDMI cable. The Wii works perfectly with this setup. You may have to go into some menus to set up the sound (I do not have external speakers yet). Good luck. I usually am not on this site but will try to monitor this site every few days for the next few weeks so post is you have questions, and I will try to help.
Disclaimer: I am not a TV tech and do not sell, represent any TV, Receiver-tuner-Amp, websites, cables, TV channels, services or other related products, nor do I own stock in any of these companies. I am a mere mortal girl who wanted to use her Wii Fit on her big screen TV.
Jan 02, 2010 | Hitachi Director''s Series UT42X902 42 in....
How to hook up a Wii to a Denon AVR 1708
If you are video switching through the Denon, you may need to make sure the inputs (analog, composite) are the same as the outputs. For example, you might have component out to the monitor, but composite in from the Wii. I don't believe the 1708 can do the upconversion. Try hooking up a yellow RCA cable from video out to the TV.
Dec 28, 2009 | Denon AVR-1708 Receiver
Video Issue with Onkyo 606 when trying to watch Cable TV.
When this happens and you just see the input label try to press the power button on the front of the cable box and see if it brings the picture up. If this does produce the picture then it is a good possibility that something is interfering with the remote communicating with the cable box. I don't know if you have it contained in an entertainment center or how you have placed your equipment but if there is glass try to clean it and also wipe down the front of the cable box and make sure there is an unobstructed view of the front of the cable box.
Good Luck.
Dec 09, 2009 | Onkyo TX-SR606 Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Onkyo TX-SR605 Receiver Logo
210 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
