SOURCE: Belkin Router: F5D7230-4 V2000 not getting correct IP Address
Although I am generally knowledgeable in networking, your issue I think still lies with your Router settings. I will however offer you a site to visit that may help you to set up your router no matter what type of service your ISP is.
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f5d7231-4.pdf
It sounds as if the computer that is wired to the router should have an ip address assigned by router somewhere in the range of 192.168.2.2 through 192.168.2.149. The router that you speak of might have the ability to be used as a "bridge" thus throwing off some of the settings. It seems as though you have the ability to have the router set up its own WAN IP. Which is for the wireless aspect of the router. Even with that though the default gateway should still be the address that you type in the browser to access your router's settings. The Belkin web site did offer a firmware update for your particular model as well and I will include that site too.
http://www.belkin.com/support/article/?lid=en&pid=F5D7231-4&aid=5388&scid=221
Good Luck
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
THE PROBLEM IS THAT THE BELKIN RTR AND THE 660 HAVE THE SAME IP ADDRESS THE QUICKEST FIX IS TO RENAME THE LAN IP ADDRESS OF THE BELKIN RTR
SOURCE: MY Belkin wireless G router does not seem to work
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
