For posted speed limits, street names, etc, corrections can be made using the map corrections tab. For correcting a home address, I do not know. In fact, I have the same problem, i.e., an incorrect or unrecognized home address was enterred that I need to correct.
i have a tomtom one, not sure if they are all basically the same, but try this. you should be able to via the settings menu. tap screen, tap 'change preferences' and scroll through the screens until you see 'change time' use the little arrows to set the correct time, and then select 24hr mode. if you are not happy with 24hr mode then select 12hr mode. if you know it is pm but sat nav is showing the correct time but in am, then simply increase the hours by 12.
If you have a picture of your current or last position Tap on the middle of the screen.
Then
In that main menu tap on change preference
Then
You will see a blue arrow pointing right. Keep
pressing it until you see an icon named set clock and change the time there, if you see a sync button do not press it since it may sync with a satellite 1hour infornt or behind.
Boot up your tt, tap the screen anywhere, then tap change preferances, tap the forward arrow until you see set clock. Tap set clock and then follow the instructions.
Hope this helps
Power up your tomtom. On the Map screen . Tap the screen , then select " change preferences " , Then scroll right until you see the " Lips " icon , Select the "Lips" under it , it says " select voice " . once in there , you can scroll left or right allowing you to choose the voice / language you require . Hope this helps.
