Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
Posted on Jun 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi Ultravision Digital 55" hdtv
While watching television last night, the tv just turned off by itself. When I turned it back on, the blue power light was on, but the temp and lamp lights both were flashing red. Now the lamp light stays on and the television will not turn back on. I went to Hitachi's website, but that was no help whatsoever!
  • Anonymous Sep 13, 2008
    I had the same problem, and i replaced the lamp bulb, now my problem is after i changed the lamp a blue spot appear in the screen, sometimes it does'nt look too big, but after a few minutes of use starts getting bigger and more visible, so i would like to know if the problem could be the new lamp (posible defective) or if is there anithing else I can do to get it fix.
    I will Appreciate any information.
  • yemito Sep 13, 2008
    do to get it fix.
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Sep 09, 2008
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302321
Points
1655
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
2answers
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
I had a power surge last night and the video on my plasma is out. I have audio but no video??
I just replaced my bulb (XL2400) on my rear projection TV. I go to plug the bulb back into the TV and I get the error (red light flashing) that indicates that the bulb or the door is not securely in place. Is there a trick to getting the bulb back into the proper place. I messed around with this for over three hours last night.
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
TV turns on for 2 second and then it is off
Your TV may have detected an error. Try first to have the TV unplugged overnight just to clear it out then observe it after turning it back on.
2answers
57t600 wont power up
Both of these problems sound like the 2 convergence ic's. Not something the owner is really able to repair. You'll need to call a svc co.
Hitachi HD big screen won't turn on. It was on, turned itself off and now won't power back up
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
HITACHI 50UX/19 CONVERGENCE BLUE DOES NOT ALLIED
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
