Step 1:
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead. The router's IP address can be changed by: 1. Running the router's setup CD. If you forgot the router's password you need to reset the router. For instructions, click here.
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be
"192.168.15.1" and if you place the router behind a primary router with
the IP address of "192.168.15.1", then the router will automatically
assume a new default IP address, "192.168.16.1".
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory
defaults. Any settings on the router will be erased. The router's IP
address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
