Refrigerators Logo
Posted on Jun 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Jun 13, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
6
Helped
46099
Points
202
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
2helpful
2answers
Why are vegetables freezing in crisper?
There is a control on refrigerator that controls the amount of cold air that is directed from freezer to refrigerator section. Locate that control and lower the amount of cold air going into refrig.
GE psc23ng...the veggie bin is freezing vegetables and temp. on fridge and freezer does stay put!!
GE Appliances Customer Phone Number Shortest Wait Best Support
GE Appliances Calls You Instead
Good Luck
THE FIX
Avoiding Frozen Lettuce
By TIM McKEOUGHPublished: March 18, 2009
Q. How can I keep produce from freezing in my refrigerator?
More Articles in This Series
Jason West, the marketing manager for refrigeration at General Electric. "Nobody really knows what the temperature of B is, or what the temperature of No. 5 is."One solution is a refrigerator thermometer. Oxo makes a handsome one with a round dial attached to a suction cup that can be installed easily on either interior side wall ($12.99 atoxo.com). Taylor makes a rectangular digital one that is installed the same way ($12.47 atamazon.com).
Once you have the thermometer, "put it in overnight and check it immediately in the morning, the first time you open the fridge," Ms. Reek said, because the temperature varies during the day as the door opens and closes.
The problem might be where you're storing fruits and vegetables, which are sensitive to cold air. Leafy vegetables are especially prone to freezing, Ms. Reek said, because of their high water content.
Although some newer refrigerators have separate cooling mechanisms for the main body and the freezer, most refrigerators cool by funneling air from the freezer into an opening near the top rear of the main compartment.
Fruits and vegetables should be kept away from this outlet, Ms. Reek said, or else "you're going to be blowing that very cold air right on the produce."
Both she and Mr. West recommended keeping produce in the crisper drawer, away from the circulating air.
"You don't want the moisture to transpire out of the product and make it limp," which can happen with produce on a shelf, Ms. Reek said.
If the crisper is full and some produce has to sit on a shelf, it's better to keep it at the front of the refrigerator, because cold air falls down along the back wall. Along with the area directly beneath the outlet, Mr. West said, "the back and bottom of the refrigerator tend to be the coldest spots."
Shirley O. Corriher, a biochemist and cookbook writer, suggests shaking off all the surface moisture from produce and sealing it in heavy zip-top freezer bags before putting it in the crisper drawer or on a shelf.
"Oxygen is a major villain, so to speak, in the deterioration of fruits and vegetables," said Mrs. Corriher, the author of "BakeWise: The Hows and Whys of Successful Baking" (Scribner, 2008) and "CookWise: The Secrets of Cooking Revealed" (William Morrow Cookbooks, 1997).
Lettuce leaves, in particular, benefit from being sealed in plastic, she said, and you should roll the bag "until you squeeze all the air out. That lettuce will keep for three weeks. It's just amazing."
Still, Ms. Reek said, "the objective of food is to eat it."
"If it's fresher, it's going to have higher vitamin content and be healthier for you," she said. "So it's really better not to plan to store food for ever and ever."
I have a new F&P refrigerator model E450RXFD upright fridge only, I have only just got it last week... I have water pooling on the bottom under the fruit and vegetable crisper part ???? any ideas what...
I have the same problem with my E450RXFD, 1st week i got it and noticed it pools water under the crisper. Not too sure what to do about it.
My parents have the same fridge (only 8 years old and theirs does not pool water)
Water has been collecting on the bottom tray of my frig (under the vegetable & fruit crispers). I have a top freezer Frigidaire. The back coils are clean and the door seals seem ok. What can I do?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
6helpful
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
5helpful
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
