One For All URC-3021 Remote Control Logo
Posted on Nov 03, 2010
Ive got a urc-3920 One for all remote . All functions works perfect , but the AV button mutes the TV. Cant change to AV with remote.I've pressed all buttons on the remote to see if it has not been switched .when pressing mute it shows the tv colour and sound menu.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1556
Points
I have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
2answers
I bought an ONN Universal Remote. I programmed it to my Dynex TV. The "ok" button is also the mute button. When trying to change the input, and hit ok after selecting the input I want, it only mutes the...
In reality the problem is that you got a generic TV which is Dynex and you really need the genuine remote perform all of the required settings and functions perfectly if you're buying also a generic remote you're going to have difficulty with this you have to try multiple settings before that remote is going to work perfectly
Ive lost the codes for my remote can someone help me please
Go here to download the .pdf file. It will guide you in finding the right code for your product. https://www.u-manual.com/download-manual-now-for-free-10/135629/remote-commander-remote-control-one-for-all-urc-3920-ofa-2.html#.Vb5uWG5VhBd
Need One for All URC 3920 remote code for VIVO 40" HD LCD TV
HI ITS 12032
BROUGHT TO YOU BY
WWW.GENUINEREMOTES.CO.UK
2answers
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Does URC-3920 Remote Control work soniq tv
Try to find it out in manual One For All URC 3920 URC 3940 Or use automatic code searching mode
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
11helpful
2answers
Codes for urc-3920 all in one tv remote
any ideas my one for all remote control is not working with philips tv after entering the code if correct what can i do model urc 11-3920
any suggestions
1helpful
2answers
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
