Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
Posted on Jun 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weak coffee Until this past week our Bunn worked great, however, suddenly it began producing very weak coffee with 5 scoops of fine coffee. Nothing changed in our coffeemaking, though we tried different approaches, but without success. What makes the machine suddenly quit making adequately strong coffee? We use it daily. The coffee comes out hot enough. Beth
  • ferrazzajerr Nov 11, 2008
    brewing cycle works,but weak coffee
Kelley Hopper
Level 2:
  • Expert 67 Answers
  • Posted on Jul 18, 2008
Kelley Hopper
Expert
Level 2:
Answers
67
Questions
0
Helped
33908
Points
172
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
My Bunn coffee maker is making weak coffee
Couple of ideas.
Your weak coffee could be due to the machine not getting hot enough, which is usually caused by calcium scale buildup on the heating element (the "burner").
Try descaling with a citric-acid based cleaner, such as Dezcal or Durgol.
The second is the coffee your using is a weak blend. Try changing to a different coffee and see if the strength is better.
Coffee brewing very weak
possible ways to remedy this problem:
problem of weak beverage
solutions:
1. Filter Type-BUNN paper filters must be used
for proper extraction.
2. Coffee Grind-A fine or drip grind must be used
3. Sprayhead-A six-hole stainless steel spray-
head must be used for proper
extraction.
4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.
5. Water Temperature- Place an empty funnel on an empty
dispenser beneath the sprayhead. Initiate a brew cycle and check the
water temperature immediately below the sprayhead with a ther-
mometer. The reading should not be less than 195F (91C). Adjust
the control thermostat to increase the water temperature. Replace if necessary.
The coffe pot will not produce full pot of coffee it only produces 1/3 then stops i cked water supply that is fine when restart it will only produce another small portion so it is three or four times for...
Check programming.This is very simple;turn switch on and hold brew switch until you here 3 clicks to start brew timer .When desired level is reached turn off on/off switch on front panel to set brew time.Check brew level now.
1helpful
3answers
3helpful
My Bunn Coffee maker has one solid stream of water running from the nozzle. It goes straight down through the filter. The coffee is weak. Isn't the nozzle suppose to spay? I thought about using a...
I work for BUNN. It sounds like your sprayhead is missing because it should definitely be spraying versus flowing. We will send you out a free sprayhead - please call our customer service department at 1800 - 352-2866 with your model and will send it right out to you.
Coffee is weak and watery
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
