It could be a few things, a hosehas a hole in it, the water pump is leaking , or the cenbter seal on the transmission is leaking. Best way to check is to put some water in it, have someone help you lean it back and look underneath to locate the leak. If the water is leaking only in the agitate cycle and not as its filling then its your center seal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
