When i put the blue ray dvd player plus surround sound through the samsung TV it gets lots of squiggly white lines. The TV and blue ray are brand new. Which is at fault the TV or the blue ray
I purchased a new HDMI cord from JB Hihg Fi and it cost me $200.00 as I thought this might be the problem but that didnt help. Is that what you meant by check the connection from recieve to tv - also I am not sure how to adjust the receive system display - where abouts it that in the bookI purchased a new HDMI cord from JB Hihg Fi and it cost me $200.00 as I thought this might be the problem but that didnt help. Is that what you meant by check the connection from recieve to tv - also I am not sure how to adjust the receive system display - where abouts it that in the book
You can't post conmments that contain an email address.
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me throughfixya.
ok
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
