KitchenAid KHMC107BT Convection/Microwave Oven Logo
Posted on Nov 03, 2010
Can I use aluminium baking tray to baking a cake in convectional mode
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 30, 2007
SOURCE: setting of a microwave
You can download the owner's manual If you will copy and pastew the entire URL into your browser's address bar:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=29957&CDCttType=UM&ModelType=C&ModelName=MT1066SB&VPath=UM/200303/20030318134829578_DE68-02235A.pdf
This will be the perfect solution to your problem.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • 195 Answers
  • Posted on Dec 07, 2008
SOURCE: i have bought samsung conection
try cake mode. (Smile)
Anonymous
  • 36 Answers
  • Posted on Jan 07, 2010
SOURCE: cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Anonymous
  • Posted on Feb 25, 2011
SOURCE: i have samsung CE103VD microwave.could
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
Anonymous
  • Posted on Jun 10, 2011
SOURCE: how to bake a cake
i have samsung microwave CE104VD. suggest how to bake a veg cake. i tried twice but not a tasty result
What it’s the difference between bake and convect bake....just for cake bake .this it’s the first time tha used Kichent aid ??
The main difference between a convection oven vs regular bake oven is how heat is circulated. A convection oven has a fan that continuously circulates air through the oven cavity. Because air is continuously circulated, convection ovens produce a much more consistent and even heat than regular bake ovens.
1helpful
I hv got a haier microwave model HIL 2810EGCB can i use aluminium dish for baking cake
No! it will cause arcing inside of the microwave oven and destroy the magnetron.
1helpful
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
Cooking temp to bake cake inn convection mode samsung model
Hope this helps
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
