TheSony Audio Interactive Radio Frequency (S-AIR) is a wireless digital audiotransmission signal that plays surround sound using a radio frequency that canbe placed anywhere that is convenient within the maximum communication distancewithout the signal breaking up. The system can transfer up to four channels ofCD quality (48kHz, 16 bits) audio data with no data compression.
You have to pair the S-Airunit with the Main HTS unit. When the sound transmission is not established,the indicator of the S-AIR sub unit does turnsoff, flashes or turns Red. Please try the steps mentioned below and checkif the issue can be resolved:
· Make sure that there is no other S-Air unit nearthe one which you're using. If any, place it more than 8 meters (26 1/4 feet)away from the unit.
· Make sure that the units that you are trying topair are within one meter (3 feet) of each other.
· Confirm that the ID of the main unit and theS-AIR sub unit are set to the same ID.
· You performed pairing the main unit and anotherS-AIR sub unit. Perform the pairing steps again with the desired S-AIR subunit.
· The unit is paired to another S-AIR sub unit. Cancelpairing.
· Install the S-AIR main unit and S-AIR sub unitaway from other wireless products.
· Stop using another wireless product long enoughto confirm if the S-AIR main unit and S-AIR sub unit gets connected.
· The S-AIR sub unit is turned off. Make sure theAC power cord is connected and turn on the S-AIR sub unit.
How to cancelpairing?
· Perform the ID setting of the unit as follows:
· Press POWER to turn the unit on.
· Press the FUNCTION +/- button repeatedly untilDVD appears in the front panel display.
· Press DISPLAY while the system is in the STOPmode.
· Once the CONTROL MENU display appears on the TVscreen, press the up arrow or down arrow to select SETUP , and then press + .
· Once the options for SETUP appears, press the uparrow or down arrow to select CUSTOM , and then press + .
· Once the SETUP display appears, press the uparrow or down arrow to select AUDIO SETUP and then press + .
· Once the options for AUDIO SETUP appears, pressthe up arrow or down arrow to select S-AIR SETUP , and then press + .
· Press the up arrow or down arrow to select ID ,and then press + .
· Press the up arrow or down arrow to select thedesired ID, and then press + .
· Once you select an ID (A, B, or C), theconfirmation display appears.
· Once you have selected a new ID (or evenselected the same ID as before), pairing is cancelled.
NOTE: To confirm the current ID, performsteps A-G listed above. When you pair the unit with the S-AIR sub unit, PAIRINGappears beside ID on the display for selecting an ID.
Pair the unit again and check if the issue is resolved.
Good Luck!
SOURCE: S-Sir Sub Unit won't pair
I almost went out and bought a Sony HDMI cable but I tried something first and it worked me. I wrapped tightly the transceiver on the back of the main unit with aluminum foil and what do you know it fixed the problem. I guess since I was using a cheap HDMI cable the foil helped to shield out the interference. Sony HDMI cable $70.00 or aluminum foil 5 cents. Let me know if this works for you as well.
Brent
mevioradio.com
