You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Hi - I'm Tina from Suddenlink. Please check our help site with information and codes for programming Suddenlink remotes: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx
Yes,buy another the tv original remote it is the best way to used the tv correctly and no headaches.Try website like Remotes.com to buy the tv original remote.
Sounds like the IR sensor in the TV may be faulty, since you have now tried a couple remotes. Make sure nothing is on the IR sensor like tape, plastic, etc. IR sensor repairs are a fairly cheap and easy repair that can be done at your local tv repair shop. If you are still in warranty you can call Philips and tell them that you tried 2 remotes (1 brand new) on the TV and neither work. They should offer you a repair option. If you have any questions regarding your Philips warranty let me know.
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Hi - My name is Tina and I am with Suddenlink. I am sorry to hear your remote control is not working. You could take it into your local office and exchange it for a new one... or, contact customer service and they could send a technician out to swap it for you. Customer Service can be reached at 1-888-822-5151.
