IF YOU WANT TO USE NETGEAR AS A ROUTER YOU PLUG THE ETH-CABLE TO IT AND START LOOK IN THE PC FOR WIRELESS NETWORK.ON THE OTHER YOU CAN CONNECT YOU DSL CABLE DIRECTLY TO YOUR PC.
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device. You need a wireless card that connects to the wireless router or wireless access point. Otherwise you can connect to your printer using a printer cable.
Unplug your cable modem for 30 minutes. Also turn off the router. After 30 minutes, plug in ONLY the cable modem. Wait about 2 minutes and then plug the router back in.
You maybe be connected (accidently) to the Internat through your neighbour's unsecured wireless network.
To configure and secure your wireless router and computer, follow these instructions : - 1. Connect the wireless router to your computer with a LAN cable. 2. Start your browser and enter the router's configuration URL 3. Enter the router setup, login and password 4. Change the admin password 5. Go to the wireless settings and change the default SSID and turn off SSID broadcast. 6. Setup encryption key the strongest is WPA2 (if not then WPA) 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router. 8. Record the settings you have made and keep it in a safe place and Save the settings. 9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router. 10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem. 2. now connect the Ethernet cable to the modem & to the computer and see if that works. else contact your isp.
what you would need to get is a wirless router. If you have high speed internet then you can plug the internet modem into the wireless router and then plug your main pc into the router via an ethernet cable and then set up your laptop to pick up the signal wirelessly. If you have dial up internet then you would still need a wireless router but it is a little more complicated. You could hook up the router to your main pc and then set up internet connection sharing so that way your laptop could pick it up wirelessly. hopefully this helps.
This depends if you connect with an ethernet cable or wireless connection. With the cable, just plug into your modem or router. If wireless, then you need to set up the wirless connection on your computer.
Cable modems and routers must be turned on in a specific way.
First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer.
Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light).
Next, plug in and turn on your router.
You should now be able to access the router and configure it for your internet connection.
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
