SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
SOURCE: Maytag MZD2766GE
Apparently, you will need to call a service man.
You may be low on freon.
Sometimes leaks occur and are not serviceable except by a service man.
I recommend that you find a service man in your area. There may be one at this website listed who would be close.
SOURCE: Frig recall which model?
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with
AND Model Numbers BEGINNING with
Side by Side
Refrigerators
AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ
ARS, CS, JC, JS, MS, MZ, PS
Top Freezer
Refrigerators
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ
AT, CT, MT, PT
Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
SOURCE: Buzzing at top of refrigerator compartment - Maytag MSD2756GE
61005988 ADAPTIVE DEFROST CONTROL NEEDS TO BE REPLACED
SOURCE: refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
