Tally incorrect version (11) ....for gold ultimate crack users...
i have solved it ...
go to data folder of tally
rename the new data 10000 to 10000n
open tally erp 9 crack version
on select company press ctrl+alt + r
your new data will not b showing
than open tally data folder again and change the name of folder from 10000n to 10000
than press again ctrl+ alt +R
now in list you will be shown with new data
press enter
the data will be rewrite in older version
enjoy...
further clarification post here
ctrl+alt+r is not working in cracked version
Thanks....Worked for me... CA Deepak Sharma (9819025531)
Thank you. this is done. resolved the problem
thanks buddy its working..
Thanks a lot
Thanks
Thanks
Works like a charm thanks a lot :))
Perfectly working
beauty full man thank a lot
thanks alot
thanks a lot
Thanks
its working for one company at a time... how can i rewrite my all companies located in tally at same time
working
IT WORKED.....THANX A LOT
Thanks. It works
Its too good. it worked fine
installed tally erp 9 then i received below msg
Incorrect Version
Data of INCORRECT ver(12)
Can only run Version 9!
Could you please help any one to solve this issue
press Ctrl+Alt+r
Thank you so much big time !! Would love to return the favor if i can be of any help.
press enter
Best option is ,drag the new version data file in to Tally.exe when tally open dont enter on select company just do ctl+alt+delete , it will rewrite the new version to old version then re open ..
SOURCE: Sub : TALLY 7.2 error
exiting tally! \r\ninternal error
software exception c0000005
(memory access violation)
SOURCE: my tally version is Tally 9 Release 1.0, my
whenever you are going to export any tally report into excel then press alt+e then press backspace and the will blink on the status of ascii,html,and xml options popup then choose ascii then choose condensed or deatailed then press enter.then close tally.after closing tally open excel, click file then open then choose c drive where the tally folder is installed then choose all files you see that a notepad is being created then click on it then choose colon semicolon with next and next procedure then it will automatically arrange in excel sheet.
SOURCE: Tally Data Recover
Here is a solution for your problem, simply use the inbuilt tally recovery tool as described here - http://www.megaleecher.net/Tally_Software
