Question about Polycom VoiceStation 300 Conference Phone
Wanted to cal two numbers at the same time form a VocieStation 300. When using the Flash button I can only switch from one phone line, while the other goes on "hold". I couldn't speak to both lines at the same time. How would I set up the phone to talk to two participants with different numbers at the same time?
  • 1,599 Answers
A Google search netted this helpful article. I appears you'll need to contact the service provider.
https://headsetplus.com/blog/make-conference-calls-3-way-calling-polycom-conference-phone/
Posted on Nov 29, 2017
SOURCE:
How to pick up the phone when 2person call in a same time?
when your using a phone with the a button for talk and end usually you can press the talk button and it will switch lines. on other models the phone will have a button marked Flash this would be the button to use. if you are using rotary phones you quickly tap the button that hangs up the receiver this will switch to the other line.
Sep 22, 2012 | Lands Phones
How do i enable call forwarding from my vtech phone to my cell phone
Hello! You can turn on call forwarding by pressing 72# then wait until you hear the two tones and dial your number that you wish to send the calls to and then hang up the phone. The two tones signal that it has understood your command and is putting the line into forward mode.
To turn off cal fowarding, press 73# and wait again for the two tones and hang up.
Apr 21, 2011 | Vtech CS5121 Cordless Phone
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
Please tell me in E-Z words how to set the clock and calendar on the Canon MP11DX calculator? Manual instructions, which I cannot locate anyway, are absolutely unclear. Please HELP!
To set the calender: Press the Calender/Time button. Press and hold the Time Set button for 3 seconds; the first digit of the date will start blinking. Then type in the date as two digit number for the month and date and a 4 digit number for the year. Add a zero in front of the month or day if under 10. Then press Time Set again. Press the CE/C button to return to the Calculation mode
(hold for 3 seconds)
Thus for today [Cal/Time] [Time Set] 0 9 1 5 2 0 1 0 [Time Set] [CE/C]
For December 1, 2010 [Cal/Time] [Time Set] 1 2 0 1 2 0 1 0 [Time Set] [CE/C]
To set the Time from the Calculator mode, you press the Calender/Time button twice before pressing and holding the Time Set button for 3 seconds; again the first digit of the current time will blink. Then type in the time as a 4 digit number followed by the AM/PM button to switch from AM to PM or PM to AM. Then press the Time Set button again and then the CE/C button to return to the calculator mode. You will see an A (AM) or P (PM) to the right of the time as you set it.
So for 5:06 PM you type
[Cal/Time] [Cal/Time] [Time Set] 0 5 0 6 [AM/PM] [Time Set] [CE/C]
I hope this helps. You can find the manual here: http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/mp11dx#BrochuresAndManuals as a pdf.
(I'm using Cal/Time for the button that has an icon that looks like a 1 month calender on the left and a clock on the left.)
Sep 15, 2010 | Office Equipment & Supplies
I have a problem with my ge cordless phone on the screen it keeps flashingthe letters CL.. just wanted to knoiw what this was
Your time needs set on your answering machine. If you have buttons on the top of your base, press and hold the day/check button to set the day of the week. Press and hold the hour button to set the hour. Press and hold the min button to set the min. If you don't have buttons on base, press flash button on handset to enter answerer remote mode. Press 8 key to enter time set menu. Set hour and min using number buttons and set am/pm using caller id buttons. Press # pause to confirm the setting.
Jan 03, 2010 | GE 25942GE2 Cordless Phone System
How to put people on three way and how to check your voicemails
For a Home Phone -Three way is easy: Just call some one or have them call you and then press the flash button and dial the new number. Then after they answer , press the flash button again and there should be 3 people on the line.
For a cell phone it's pretty much the same except instead of pressing a flash button you push send and the phone will ask if you want to have a conference call which is 3 way.
To check your voicemail dial your phone number and press *Star or #Pound (depending on the phone) this will take you to the voice mail menu. If it asks for a password and this is the 1st time your using it, dial in your phone number without the area code.
Jul 28, 2009 | Lands Phones
Form creat in flash
  1. Create a new document and set the size to 400 x 300 ("Frame" > "Frame Size")
  2. Set "Frame 1" to "Stop" ("Frame" > "Frame Delay" and check "Stop", click OK)
  3. Draw 2 edit fields with the "Edit field" tool, they will appear as Edit1 and Edit2. Double click each field and make sure HTML is not checked, uncheck if necessary.
  4. Draw a button, double-click it and rename it to "OK".
  5. Draw edit field labels "Phone" and "Email" with the text tool. Double click each field and make sure HTML is not checked, uncheck if necessary.
  6. Draw "ErrorMessage" field with the "Text Paragraph" tool. Choose "Item" > "Text Color" and change it to red. Choose "Item" > "Placement Properties" and rename the field to "ErrorMessage"
    1. Select the button, choose "Item" > "Actions" > "OnClick". Select "ActionScript" and paste the following code:
    // reset error message
    ErrorMessage = "";
    // validate phone field
    phone = Edit1;
    if(phone=="") ErrorMessage = "Enter your phone";
    // validate email field
    email = Edit2;
    if(email=="") ErrorMessage = "Enter your email";
    if(email.indexOf("@",0)<0) ErrorMessage = "Enter valid email";
    if(email.indexOf(".",0)<0) ErrorMessage = "Enter valid email";
    // build message string
    message = "mailto:support@selteco.com?subject=Title&body=Form contents%0A";
    message = message + "phone: " + phone + "%0A";
    message = message + "email: " + email;
    // execute form if errormessage is empty
    if(ErrorMessage=="") getURL(message,"_self");
Hit F9 to preview. The form will not work until you export Flash file and HTML page. Choose "File" > "Export HTML Page" to create HTML page and test the form in a browser. This form is using very basic validation. Use "%0A" as line separator.
Use the following functions or attributes of the string:
  • length returns the number of characters
  • charAt(x) returns zero-based character at position x
  • indexOf(substring,startindex) returns the position of the first occurrence of the specified substring or -1.
  • lastIndexOf(substring,startindex) returns the position of the last occurrence of the specified substring or -1.
  • substr(start,n) returns n characters string starting at specified position
  • toLowerCase(), toUpperCase() converts the string to lower or upper case
Jan 21, 2009 | Computers & Internet
I forgot my n73 keyguard code
hi junaid i have a sol for ur prob. just flash ur your phone or restore UI settings by the flasher that supports phone model. in case UI u will get the default code 12345.
Sep 27, 2008 | Nokia N73 Cellular Phone
Wanted to use two mitel 5303 for one conference call
Yes you would have to have them on seperate analog phone lines and 1 would have to dial the other. To add a 3rd party you have hit the flash button dial the other party, connect, and hit flash again.
Mar 19, 2008 | Mitel 5303 Conference (50001905)
My Meter Won't Move
weather can effect your meter .Those meters are not very accurate just a base line get a good swr meter and then check it.If your getting good radio checks it could be the potentoimeter is dirty . Radio shack sells contact cleaner and lube try cleaning it . That might help
Jan 08, 2008 | Cobra 29 LTD CB Radio
Polycom VoiceStation 300 Conference Phone Logo
76 people viewed this question
Top Polycom Lands Phones Experts
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
