Citizen EcoDrive Calibre 3100 BT000007E Watch Logo
Posted on Nov 02, 2010
The watch has stopped working does not appear to charge
I left my timex solar watch in my watch case too long - and it stopped working. How do I repower the watch. (I have had it out in sunlight for a couple of days).
I am thinking you need a new battery. It appears to be a battery operated watch that runs on solar power IF there is light.
How long will a Timex Solar watch last?
The solar movement functionality creates an environmentally-friendly and maintenance free timepiece that can be charged through indoor fluorescent light or outdoor sunlight. Once fully charged, the battery life can reach two months. If worn daily, there is very little chance the watch will stop.
Solar Powered Watches ' Timex Blog
1helpful
How do I display the charge indicator on a citizen skyhawk C652 watch ?
i believe the chg indicator is the second hand - I have a citizen eco drive - if it double steps the chg is weak. a single step for each second is normal.
Sep 21, 2014 • Watches
How do i recharge a watch pansonic battery mt 516
My watch was in the drawer for over a year and stopped working. I flashed my iphone torch directly on it for literally about 3 minutes and BRAVO it's working again.
Oct 09, 2012 • Watches
WATCH STOPPED RUNNING
Something may be stuck in the works of your( a small peice of debris) mechanical watch.I had a similiar problem with a watch of mine my watch Guy was abletoopen itupblow outthe debris stopping the works and get it going again .I thinkhe charged me 5 bucks .Itcould be something that minor.
Pulsar Chronograph 100 m - The second hand on the left small dial (not the sweep second hand of the stop watch) has begun moving erratically. It appears to move for two counts and pause for three and then...
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
1helpful
Watch Stopped Working
The battery is empty, replace it yourself or take it to a local watch repairer / dealer, he or she will probably charge you around 5 $ for the new battery and replacing it.
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Watch stopped working
I fixed my problem by pulling the crown out to position 2 and then put it in the light, cause I tried to put it in the light without pulling out the crown but it would not charge
May 02, 2009 • Watches
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
