SOURCE: upgrade vga & processor for elite P4M800-M7
Hi kapitan, for starters the AGP is faster than a PCI. Yes, you can upgrade to 512MB. There is a direct path to the CPU when using an AGP video card.
Elite Group has 2 P4M800-M7's. One is version 1.0 & 3.1.
Though both boards are very similar they are different when it comes to CPU support.
When you view the main pages for you're Elite Group P4M800-M7. Look to the left for CPU Supported & click it. I'll list both boards along with their link to supported CPU list. You will need to find the version number (on the board) in order to pick the correct CPU supported per version number.
Link 1, Version Number 1.0
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=531&CategoryID=1&DetailName=Specification&MenuID=7&LanID=9
CPU's supported. V1.0
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=531&MenuID=69&LanID=9
Link 2, Version 3.1
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Specification&MenuID=7&LanID=9
CPU's supported V3.1
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=548&MenuID=69&LanID=9
Depending on the version number you can reach CPU of 3.8MHz.
Hope this was helpful.
Feel free to ask if you need more service.
Good Luck!
Mike
SOURCE: P4M800-M7
Hi jora, it is all based on what version you're motherboard is!
EliteGroup states the P4M800-M7 v3.1 does support the dual core CPU. (It does not mention this in the manual but does state this on their main web site for the motherboard P4M800-M7 (ver 3.1). (This link).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=548&DetailName=Feature&MenuID=1&LanID=9
EliteGroup, supported CPU's for P4M800-M7 (ver 3.1)
However, EliteGroup P4M800-M7 (ver1.0) does not support dual core CPU's. (This link)
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=531&DetailName=Feature&MenuID=1&LanID=9
Supported CPU's (v1.0) (This link).
So you need to find the version number of you're board.
Good Luck!
Mike
SOURCE: elite P4M800-M7 Motherboard
You could go as high in memory as you can find. You need to stay with the AGP bus though. Newegg has a good bunch of 512 mb AGP cards some even have DDR3 and that caught my attention.They'll set you back between 50 to 100 bucks for the realy good ones.
SOURCE: Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
SOURCE: my biostar P4M800 Pro-M7 only shows 1gig of ram, but i have 2gig... Wat could be the problem?
Are both chips identical ? if so
Take out the ram and replace it one stick at a time in the socket 0 or 1
If both sets of Ram work then check your instruction book on the motherboard and see what is the maximum ram it will take .
Get a copy of Memtest86+ from www.memtest.org
and run it on both chips , that will show if there is any errors on them.
Need to know if there is an error message before we go further. Have you got an anti-spyware program installed as spyware can do this. If not download / install Malwarebytes / update and scan all files. NB = If you do have one uninstall it first.
Check that the CPU cooler fins are not clogged as it may be overheating.
NO HISTORY TOLD. it is 11 years old in your hands., P4 mobo, relic 2006
did you ever see it run perfectly its whole long life? and uses junk class VIA chip set
no longer supported by VIA ! avoid VIA
North Bridge: VIA P4M800 Pro. 2009 last driver.
South Bridge: VIA VT8237R PLU
DDR400/333/266 SDRAM , DDR1 (oldest) max speed 400.
the last drivers on earth here here
Windows XP,Windows XP 64-Bit,Windows ME,Windows 98SE,Windows 98,Windows 2000,Windows NT,Windows Vista 32-Bit,Windows Vista 64-Bit,Windows Server 2003 x64
VIA Hyperion Pro Driver Package
http://download.viatech.com/DriverDownlo...
but is now infected, OEM site is infected
RIP VIA
now the shuts off (rests in bios or windows or both?) not told.
LIST: of causes
PSU bad , no it is new
PSU 4 and 20 pin cable not plugged into,
20pin is legacy PCU only here.
4 pin JATXPWR2, must have power. too.
PSU overloaded,, at any time it shuts down to end that fire thing if failed to do that.
CPU wrong, bent pins ON SOCKE or wrong CPU
BUY USED MOBO FROM YEAR 2006 GETS BENT PINS.cpu
CPU overheating, or its fan dead or too slow.
usng wrong DDR1 ram.
DOes BIOS screen work ,they must and did it hold BIOS screens for 1 hour, not shut off (a goal)
new coin cell is need, not simply replaced
NEW ONLY !
half all all AGP card made will not work on this MOBO chip set, the make has QVL list
that show that do pass muster.
2006 reviews, on it bleed hate. and deserved.
USB shorts
Pci or AGP card shorts. remove them all
HDD or ODD short, unplug all that
go to just this min. level
PSU +MOBO +CPU + 1-stick of DDR1, + new coincell and a MONITOR NEWER THAN 2010.
vga JACK, No AGP ALLOWED NOW,
GET BIOS WORKING FIRST, FOR GET WINDOZ ,ETC.
FOR NOW.
