Computers & Internet Logo
Posted on Jun 12, 2008
Setting up for broadband
Equipment: Dell Inspiron 1720 with Vista Home Premium
D-Link DSL-502T ADSL Router.
All the above bought in New Zealand where I use Telecom NZ broadband.
I am in UK for 3 months. Have signed-up for Plusnet broadband (most others require 12 month contract). I am told I need to set up my D-link but I don't have the manual with me and haven't a clue where to start (can't find website for getting a manual.
Using Waitrose dial-up to get me by but need broadband a.s.a.p.!!
Regards
John Maclaren
56 Morning Star Road
Daventry
NN11 9AA
UK
tel: (01327) 704089
email: [email protected]
Can you tell me where to download a manual
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jun 12, 2008
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
31595
Points
81
First, you might want to check with Plusnet the login information and the type of the authentication they have. Secondly, setup your router, login to your router using a web browser. Type 10.1.1.1 in the address bar and press enter key.Login using the default setting username 'admin' and password 'admin'.
Click on Home tab and then on WAN on the left side of the screen.Select PPPoE/PPPoA option.Under Connection Type select 'PPPoE LLC' in the drop-down menu.Enter username and your password.Please check with your provider if not sure again.
If you have connection with static IP address, you do not have to specify the IP settings on the router: the router will be getting the same IP from your ISP every time it connects.Click on Apply. To save the settings into the router's memory go to Tools > [System] > Save and Reboot.Give the router a minute or two to reboot and reconnect.
Lastly, Restart your computer and you should be able to access the Internet.You do not have to run any login client on any of your computers because your router logs to your ISP automatically.
or check this URL;
ftp://files.dlink.com.au/products/DSL-502T-GenII/Manuals/DSL-502T_GenII_Manual.pdf
How can I obtain a user guide for Acatel optus one touch 250 P/N16513 corded phone?
Optus Network Approved modem and equipment list
If you are supplying your own DSL modem and/or telephone filters, you must ensure they meet the requirements
below before connecting them to the OptusNet DSL network. Connection of unapproved equipment is prohibited.
The modem list contains equipment that has been certified by manufacturers as having passed interoperability tests
r
equired for use on a DSL network. If your modem make and model isn't listed below,
call Optus Customer Service for further information on
1300 309 333.
F
ully supported by OptusNet DSL Broadband Customer Service, the OptusNet DSL Broadband Installation CD-ROM will automatically
c
onfigure this modem.
D-Link ADSL Modem 302G
The OptusNet DSL Broadband Installation CD-ROM provides detailed information to manually configure these modems, and OptusNet
DSL Broadband Customer Service will provide limited connection support for them.
(Equipment Certification date in brackets)
F
or modems and routers other than those above, OptusNet DSL Broadband provides only the network connection settings needed for
manual configuration. While this equipment can be used on the OptusNet DSL Network, no OptusNet DSL Broadband Customer Service
will be provided for connection configuration or equipment-related connection difficulties.
Alcatel SpeedTouch - 510 ADSL Modem (15.01.2003)
Alcatel SpeedTouch - 530 ADSL Modem (15.01.2003)
Alcatel SpeedTouch Pro - 4 port (10.09.2001)
Alcatel SpeedTouch Pro - Firewall (09.10.2001)
Alcatel SpeedTouch PCNIC (04.08.2000)
Alcatel SpeedTouch USB (04.08.2000)
Askey/Dynalink - ALE 070 (08.01.2001)
Askey/Dynalink - ALH 110 (21.03.2001)
Askey - RTA100 ADSL Modem (25.10.2002)
Billion Electric - BIPAC-711 CE ADSL Modem (25.10.2002)
Cisco WIC - 1ADSL-DG (30.06.2003)
Cisco 827 (19.02.2001)
Cisco 827H (11.07.2002)
Cisco 827-4V (19.02.2001)
Cisco 837 (01.04.2003)
Cisco SOHO77 (29.11.2001)
Cisco SOHO77H (11.07.2002)
Cisco SOHO97 (01.04.2003)
D-Link ADSL Modem - DSL 100D (08.08.2001)
D-Link ADSL Modem - DSL 500 (08.08.2001)
D-Link ADSL Modem - DSL 504 (08.08.2001)
Efficient Networks - C10 Communications - Speedstream 3060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 4060 (08.01.2001)
Efficient Networks - C10 Communications - Speedstream 5260 (08.01.2001)
Efficient Networks - Siemens - Speedstream 5400 (07.04.2003)
Efficient Networks - C10 Communications - Speedstream 5660 (21.03.2001)
Efficient Networks - C10 Communications - Speedstream 5667 (10.09.2001)
Efficient Networks - C10 Communications - Speedstream 5861 (21.03.2001)
Juni NetAce - ADSL USB Modem (15.01.2003)
Juni NetElite 2000ES - ADSL 4 port Modem (15.01.2003)
Juni/Samsung SAM-215 USB Modem (18.07.2001)
Juni/Samsung SAM-335A Ethernet Modem (18.07.2001)
NetComm ADSL Modem - BusinessSmart (08.08.2001)
NetComm ADSL Modem - USB - NB1200 (27.08.2002)
NetComm ADSL Router Modem - NB1300 (20.11.2002)
Open 501r ADSL Router Modem (05.04.2002)
Alcatel - Central, Part No. 3AU 04804 AAAA
Alcatel - In-Line, Part No. 3AU 04805 ABAA
Askey/Dynalink - In-Line, DT60-002BA
C10 Communications - Dynamic - In-Line, C10290
C10 Communications - In-Line, C10611 & C10611T
C10 Communications - In-Line, C10645 & C10645T
C10 Communications - In-Line, C10610
Te
l
ephone Equipment - Central, TE-ACP20AUS01
C10 Communications - In-Line, C10211
C10 Communications - In-Line, C10111
C10 Communications - In-Line, C10145
C10 Communications - In-Line, C10245
D-Link - Central, DSL-10SP
D-Link - Central, DSL-10CF
D-Link - In-Line, DSL-10MF
Alcatel SpeedTouch Home
D-Link ADSL Modem - DSL 200
D-Link ADSL Modem - DSL 300
D-Link ADSL Modem - DSL 300+
D-Link ADSL Modem - DSL 302G
Optus supplied modem
Optus preferred modems
List of all other certified modems/routers
List of certified filters/splitters
Information correct as at 2 February 2004.
1270049 06/04
Nov 12, 2014 • Cell Phones
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapterhttp://www.ebay.com.au/itm/USB-2-0-MIC-Speaker-5-1-Audio-Sound-Card-Adapter-/120645945426?pt=AU_Laptop_Accessories&hash=item1c170f0852
hope this help
2answers
D-link adsl router driver model no dsl-502t
Click on the link below to download the d-link DSL-502T driver, after you download and install it, restart your computer for the changes to take effect:
http://members.driverguide.com/driver/detail.php?driverid=741867
Problem with my adsl 2+ router glb-502t
check if you have the correct username and password for the ADSL line entered into the router, if its correctly entered then reset the router once it should ideally pich up the ADSL Connection.
1helpful
GLB 502T ADSL 2+/Router DRIVER Dlink make
Most of the time, one _NEVER_ needs to install _ANY_ of the software provided with a D-LINK router -- it just works correctly straight "out-of-the-box".
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
502T usb drivers for win98se
i suggest you upgrade to xp or other your choice try looking online for the specific driver
4answers
Install software for vista premium for my mn-100 router
router do not require software unless this is a usb version.
2answers
About D-Link Modem
re-configure you modem and check it your ipaddress and dns value
Grand Canyon Tech
Grand Canyon Tech
