Your problem is the 4GB card. The Raymarine C-Series have a problem with their compatability tool and larger CF cards. You should use a card no bigger than 256mb.
The card probably worked in the store because the newer models accept larger cards.
Get an older card from ebay etc and copy your 4gb files onto it and try again. There is more info here: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1042&p_created=1089743435&p_sid=Y9eWB6ek&p_accessibility=0&p_redirect=&p_lva=1042&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjYsMjYmcF9wcm9kcz0zNiwzNTIsNDEmcF9jYXRzPTAmcF9wdj0zLjQxJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1zaXplIGNhcmQ*&p_li=&p_topview=1
Hope that helps you out.
Yep, let me know how it works once you have a different card. There is a fair chance that the older 2005 gold chart won't be compatible until the C80 SW has been updated.
Hi Flak,
Glad I could help and more importantly you got your problem sorted.
Would apprecaite you rating my help if possible, thanks
Adam
These types of problems are model specific the best way to find out what is wrong, is to check the paperwork that came with the plotter. Towards the back of the instruction manual they will have a phone number to call for assistance. It sounds like the plotter may be defective. And may need exchanged.
The first advice is no help at all. I have already studied all the literature, and consulted the Raymarine web pages, and followed all instructions to the letter. The advice I am looking for will only come from someone who actually knows this plotter and likely related to my two questions in the original enquiry.
I will follow through with a smaller CF card in the next fwe days. However, the other Navionics gold card that also froze the C80 is actually 128 MB, so I have some reservations about the solution with the smaller card until I try. Mabe after the SW update the 128 MB Navionics card will work.
Thanks;
flak230
I borrowed an old CF card from the store, and updating the SW to 5.04 went first time, no issues. However, the 2005 gold CF is no go. The card must be damaged. The store also had problems with it in one of their plotters. I will buy a new gold CF in the near future.
Thanks for your help!;
Adam
This second expert zeroed in on my proble, excellent solution.
I used a 256 but still no go. Something wrong with my card reader?
