Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Use the kitchen aid grease
KitchenAid recommends the Benelene 930-2 grease, this is a food grade, non-toxic vegetable based grease.
KitchenAid's part number for the grease is 4176597, it usually only comes in a 30 oz can which is way more than you need for a household repair. We repackage the KitchenAid grease into 6oz & 10 oz containers.
When repacking the grease the k45 mixers use approx 6-8 oz of grease so we recommend the 10oz grease container so that you have plenty for regreasing your mixer.
Here is a link to the KitchenAid 10oz Benelene Grease: KitchenAid Mixer Gearbox Grease 10 oz for 4 5 5 Quart Mixers
-Colleen@MendingShed
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
SOURCE: Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
SOURCE: Need Kitchenaid k45ss manual
Hi. All of you should goto www.kitchenaid.com and enter your model# into the search window. You can download Operators and Parts manuals for your model. Kitchenaid does not provide Service Manuals but the parts drawings will be very helpful with disassembly and reassembly.
If this solution has assisted you, please rate. ricardok45
