Jenn-Air JJW8230D Electric Double Oven Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does it keep turning off?
I have turned the power off and on and get an error code of EE-217/M-217. What does this code mean?
Jorgie the appliance guy
Level 3:
Top Expert:
  • Jenn-Air Master 5,639 Answers
  • Posted on Jul 23, 2023
Jenn-Air Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523269
Points
32630
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
2 Related Answers
Anonymous
  • 230 Answers
  • Posted on Jan 07, 2010
SOURCE: how to fix F1 error code
HI There
I have this code for you to read and this is helpful. Let me know how it goes.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.Thank you for writing to fix ya.
Best Regards Richard
Anonymous
  • 523 Answers
  • Posted on Apr 24, 2010
SOURCE: Jen Aire oven / micro combo unit. Display code F7.
change the probe
2answers
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 • GE Ovens
2answers
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 • GE Ovens
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 • Ovens
Whenever oven in on 350 bake, temp keeps going up. Finally had to turn breaker off. It showed f2 on error code
Hi... an F2 code means you have a bad "temp sensor" They are really easy to instill
Double oven is having an alarm sound and showing F7, what does that mean??
hello,
what this means is any indication of code error indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
There is a chance that there is a loose wire connection on the water temperature
thank you and thanks for using fixya.
Jun 07, 2010 • Ovens
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Says f1
F1 error code usually means that the oven temperature has exceeded 590 degrees. Usually this means that the oven temperature contol sensor ( or thermostat) has failed allowing the heating element to overheat the oven.
To correct this you will need to fit a new sensor. Sometimes the error code can mean a temporary glitch which may be cured by turning off the power for 30 mins and then resetting but if the problem persists then a new sensor is the answer.
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
2answers
Wall oven error code
Having the same problem.
Has anyone found a solution to this problem?
Thank you
David
m5beemer(at)gmail.com
1helpful
4answers
F7 error code
f-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
