Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
Posted on Jun 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connect sirius fm adapter to 2008 honda civic sedan radio
Installer having problem connecting sirius radio fm adapter to 2008 honda civic sedan antenna. he is going in thru the glove box and can not reach the fm antenna? Help.
[email protected] or [email protected]
  • 3 more comments
  • heick Jun 16, 2008
    We have the FM channel working, but without the connection I am getting static noise. The installer cannot reach the antenna thru the glove box and I dont want him to take the dash board off.
    Is there an easy way to get to the car antenna? Thanks.
  • heick Jun 19, 2008
    This does not tell us how to get the radio out. There is no faceplate that comes off on this radio.
  • heick Jun 23, 2008
    We will try this.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this using a black box to plug the car antenna into so the Sirius will use the direct fm channel setting?
  • Anonymous Mar 13, 2014
    How can I get the radio tuner to stop at a dead fm station?
A
Anonymous
Yes. Factory installed radio.
Tim Babcock
Level 3:
  • Master 2,794 Answers
  • Posted on Jun 16, 2008
Tim Babcock
Master
Level 3:
Answers
2794
Questions
13
Helped
1128350
Points
7249
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Have sirius and hands free phone features with sirius antennae. I do not get good signals from local FM or AM Radio stations. Why?
Sirius is a satellite biased service , so it uses a satellite antenna , local stations how ever don't use that antenna and use a dipole antenna , are both type antenna's connected to your radio , lots of installers don't bother to connect local antenna to new radio installs , im mean you got Sirius why'd you want local stuff anyway is there thinking
2helpful
Radio antenna
YOU NEED TO CONTACT SIRIUS CUSTOMER SUPPRT
Delphi skyfi won't connect to my fm radio automatically.
The audio plug overrides the FM frequency setting. That way if you use a tape adapter to run the music through it will use that source instead.
A lot of FM channels are getting crowded into a lot of markets out there. The best way to fix the problem is to use a direct FM module. This way your Sirius will override the FM channel whether it is used or not.
Here is a link for one:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1998401&catParentID=7872&scId=7872&oldParentID=7872
they are very easy to install.
How to hook up the sirius stratus 5 radio in my 2008 rav4?
I have sirius installed in my 2008 RAV4 JBL system.
There is an adapter made by VAIS technologies http://www.vaistech.com/ that is called a soundlink. It comes with instructions for the connection. The Sirius radio is hidden in this installation, and is controlled by your JBL system. The antenna runs up the side of the windshield (hidden behind the plastic moulding) and mounts to the top right corner of the roof.
HOWEVER- you will not have the full funcionality of the Stratus 5 radio- which has more funtionality that the JBL system can control. Also, the Scrolling feature on the Stratus 5 screen does not work on the JBL display. . . you get the first 15 or so characters, with no scrolling.
I love having an integrated satelite radio in my car, but I do miss the better screen, and the pause feature I had on my sportster (in my old car). Good Luck.
2003 Honda Civic Radio
the fast way to connect an mp3 player is to buy an mp3 FM converter. it has this small input hole where you can use the wire included with it and connect it to your headphone of your mp3 player and then listen to it in the FM channel.
tnx 4 using fixya,
drcool
Sportster 4
Shouldn't need one. Does the rear antenna connect to the direct FM box?
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Connecting Sansa e260 to factory car stereo
there's hardwire kits (http://www.crutchfield.com/S-oVN2ByB3OJo/App/Product/Item/Main.aspx?g=234550&I=142FMMOD01&id=review) and tape deck adapters. sirius might work if only audio jack is needed
2answers
FM Modulator
I haven't found any ways that work. A better option is to use this device http://www.xm-sirius-satellite-radio.com/SIRIUS_FM_Direct_Adapter_p/fmda25.htm to make a direct connection into your radio's antenna plug. This adapter allows your satellite radio to provide clear, static-free sound. It can be difficult to install, however, depending on how hard it is to get to the back of your vehicle's radio.
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
