NO OS stated.
i bet it not 220US (us means usa,what is your 2 letters there)
if it was US Laptop
the books is free at HP to read.
http://h10032.www1.hp.com/ctg/Manual/c01487709
unlock i bet you mean set to non secure AD HOC wifi mode.
and a danger, that is.
first discover how your router is setup., only you can do that
read the manual in it,the go there in your browser and set
the wifi up as you want or set up your pc to match it.
set SSID broard case to like ROVER2. (dog name ?)
the set encryption to WPA2
then set the passphrase. like 1a5!9xaz3k6
the connect all things that way.
dont tell the other 512 your settings, ever.
your pc came with 802.11b/g wifi
im reading your manual now on line it says
this.
shows it came with 3 wifi chips (options)
here is the spec, for 2nd one,(coin toss)
128-bit WEP, 64-bit WEP, AES, PEAP, TLS, TTLS, WPA, WPA2
so if you set the router to wpa2 and same in your PC and it will work.
SOURCE: no wifi
You need to get a wireless adaptor your laptop did not come with wireless built in. You can get a USB adaptor or a PCMCIA adaptor. Either will work but the pcmcia adaptor will be a little faster
Have a look here
http://www.google.com/products?hl=en&q=pcmcia+wireless+card&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Hope that helps
SOURCE: the drivers of window compac presario cq60 104tu XP professional
select your model from here and downlaod
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=89327&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
SOURCE: hello. i have a compac presario f700 notebook pc.
motherboard drivers
compaq laptop c700 drivers
