When you turn on your computer, press F8 and that will give you some start up options, the first ones being Safe Mode, Safe Mode with Command Prompt and Safe Mode with Network.
Please restart your computer and keep tapping the F8 key till the time you get the startup options for your system.
You will see option like 1. Safe mode 2. Safe mode with networking etc.
Select Safe mode and your computer will boot into safe mode. If you want to exit from safe mode and want to login on the normal mode then you will just have to restart your system.
Hope it Helps
Thanks and Regards
Anand Sachan
SOURCE: start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch. As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
SOURCE: my touchsmart iq770 wont run windows vista unless
Here are the steps you need to follow to fix the problem: Turn off the computer and unplug the power cable,press and hold down the power button for five seconds.Reconnect the power cable and turn on the computer. Press the F10 key once every second for five seconds after the computer is fully turn on,after five seconds press the F5 keys this will restore the original settings for the BIOS.Press the enter key to accept the changes.Press the F10 key to open the save and exit window. Press the enter key to save the changes,exit the BIOS and then restart the computer.After the computer is is restart the hp logo should display on the screen and the computer should work fine.
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
(Choose Safe Mode Withnetworking)
Once in Safe mode Run a Full Scan with Malwarebytes
http://www.bleepingcomputer.com/virus-removal/how-to-use-malwarebytes-anti-malware-tutorialFollow steps on installing, updating and running a full scan with Malwarebytes.
If you are running Safe Mode because you cannot get into Windows, you may want to first try
loading the last known good configuration.
To
get into the Windows 2000 / XP Safe mode, as the computer is booting
Note:
With some computers, if you press and hold a key as the computer is
booting you will get a stuck key message. If this occurs, instead of
pressing and holding the "F8 key", tap the "F8 key" continuously until
you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode
- If after several attempts you are unable to get into Windows 2000 or
Windows XP Safe Mode as the computer is booting into Windows, turn off
your computer. When the computer is turned on the next time Windows
should notice that the computer did not successfully boot and give you
the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once
you're done in Safe mode if you want to get back into Normal Windows
restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To
Note:
With some computers if you press and hold a key as the computer is
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
