Whirlpool Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
4 Digit Failure Codes (for 2 digit codes see below)
F1 - E0
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
F1 - E1
EEPROM checksum error
F1 - E2
UL A/D error(s)
F1 - E4
Model ID error
F1 - E5
Calibration shifted
F1 - E6
Latch signal mismatch error
F1 - E9
Stack overflow
F1 - E3
Wiring harness cavity size does not match previously stored value
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
