You haven't said the exact model of your Stax amps so i can't be very precise but most Staxs don't run with less than 1.5 ohm loads or when in series/push-pull configuration.
You haven't said the exact model of the protection system and at what rating it's set - if it's external. Maybe the current at which it gets activated is lower than what both amps are drawing at full power.
Maybe you connected the amps wrongly - the phases aren't aligned.
This also happens when the outputs aren't perfectly in sync and at equal value - check the preamp and the inputs.
In either way make sure of: the inputs to the amps are identical in every way, the amps are in parallel (watch the phases), the sub is wired at 2 ohms and all the wiring is as equal as possible..
