Sounds like the fan motor is at fault , 1 it could have bearing problems
2 the capacitors if it has are at fault , to correct check fan with out power to see if it runs free if it runs smooth then i suspect the capacitors are at fault , you will need a megger to check both items , make sure you check that they both accept a charge of 500 volts and that they discharge , if one does not , then change for a knew one ,
