Question about Motorola Mobility MD681 5.8 GHz Digital Expandable Cordless Phone (2090262945)
Hi i have motorola md681, 5-6 years old. batteriy's gone. so i am thinking of buying a new battery but its too costly ($10). i have a battery which has 3.6V 400mAh Ni-Cd. can i use this battery as an alternative to my dead moto battery (2.4V 1400mAh NI-MH). Thanks in advance.
  • Motorola Mob... Master
  • 26,370 Answers
No you can't use that battery as it is too many volts and will fry the circuit boards!
$10 is cheap, $7.00 is better with free postage.
Amazon com Motorola MD681 Cordless Phone Battery Ni MH 2 4 Volt 1500 mAh...
Posted on Mar 05, 2018
SOURCE:
My Philips TV is over 10 years old and has now got Green Hues all over the screen. Is this going to be an expensive fix or do you suggest a new TV now that my area is going over to digital shortly. I am...
You will spend lots of get this 10 year old TV repaired and it is still a 10 year old piece of electronics. The price of TVs has gone down so much that you can more than likely buy a brand new 32" LCD widescreen HDTV for what is will cost to repair this one. You could spend money to repair this one and then something else could go wrong. My advice it to junk it and buy a new one.
Jun 12, 2011 | Computers & Internet
Where can I get a new rechargable battery pack? Mine are 5 years old and no longer holding a charge.
See: http://www.batteryuniverse.com/Two-Way-Radio/Motorola?gclid=CO7npdfTyaUCFVB95QodeU98Zg
The batteries cost almost as much as a set of new radios
Nov 30, 2010 | Motorola TalkAbout T5530 2-Way Radio
Is it worth to keep my 1990 Toyota Corrola if THE MILEAGE IS 99,560 miles as of today. I have just get oil change and minor maintenance last saturday, 11/13/10 and spent $650 for new starter last 3/10/10...
The easiest way to figure out if it is worth keeping is to add up the cost of repairs for last year. Do not add oil changes, tires,gas or brakes because these need to be done on a new car as well as an old car. When you have a total for repairs for the year divide that number by 12. This is what it costs you to drive your car. If this is less than the monthly payments on a new car then keep the old car. Hope this helps.
Nov 20, 2010 | 1990 Toyota Corolla
Not condensing
Check to see if coils are getting cold, (run for 10 min. then unplug, and check inside unit). If they are, check and clean filter and coils. If not, most likely no economical to fix. Check consumer reports before buying a new one. New standards came in to play this year. Changed quality on the units.
Jun 02, 2010 | Maytag M7DH65B2A Dehumidifier
We're thinking of buying a new motor on this 10-year old machine. Is it worth it at half the cost of a new machine? What's the next most likely part to fail?
AT 10 years old, anything is likely to fail, bearing in mind that every moving part has had 10 years use.
I personally would purchase a new appliance, for one thing , you are starting off with a guarantee on the whole appliance, as the only guarantee on repairing your other one , would be on the motor.
Get that replaced, and next week, something else could go wrong.
Hope this helps to make up your mind
Jan 10, 2010 | GE Profile WPSR3120WWW
Hi,my name is PK I have 5 tons Rheem air handling 10 year old. it is vertical type. How to fix the leak at evapolator coil. it leaked at the bottom right side. Can I use epoxy to seal this leak.Or replace...
Epoxy wont hold you need a new coil. about 8 to 12 hundred depending on your location. If it is 10 years old I would suggest you change the air handler. You will get a lot more efficient unit. Cost about 2200 but you will get a 10 year warranty from most manufacturers. Dont buy one unless you get a 10 year warranty. Russ
Jul 28, 2009 | Heating & Cooling
Razor
HI,
Every phone battery has a life cycle. if the battery is more than year old , it most probably requires a replacement. As its not able to retain charge. If its under one year , get the same replaced from the motorola service center . I had the same problem with my razor and they replaced it free of charge as the same was under 1 yr .
Thanks
Proton
Apr 22, 2009 | Motorola Mobility RAZR V3c Cellular Phone
I have had this razr 4 a few years when i plug it in to charge it turns on 4 10 secand kuput it doesant work!!!!I NEED HELP!!!!!
mostly battery is gone..... you can expect too much from motorola...... try to change battery if it works or go for new. mine is also crashed after using for 3 years. Its just hanged. I count not do anything.
Mar 27, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Texas Instruments TI-30XA Calculator Problem
Either battery is dying, or circuit board has gone, or connector cable loose.
You can replace battery by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA for $10 from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 04, 2008 | Texas Instruments TI-30XA Calculator
Coffee pot leaking
Your brewer has a 3 year warranty. If you will call customer service with the model and code date and it is less than 3 years old, we will replace it with a new machine at no cost. If it is over 3 years old, we will replace it at a reduced price.
Aug 12, 2008 | Bunn GR10 Coffee Maker
Motorola Mobility MD681 5.8 GHz Digital Expandable Cordless Phone (2090262945) Logo
49 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
