You have two options you read the booklet or you use pin button also you can consult with watch seller. DiscountedWatches247.com
It does seem strange that no instructions come with your watch, although this seems to be a fairly common problem.
If your watch has only a crown wheel and no other buttons, perhaps they feel that instructions are not needed.
In any case, the crown wheel should not come out when you pull it, as this is clearly what you are intended to do in order to set the time.
I think you have a faulty product and suggest that you return it to the supplier and ask for a replacement. Even a cheap watch should work! I have bought several cheap watches and they have always worked for years.
