Question about Humminbird Boating
Have recently installed a Humminbird Wide One hundred Model which I purchased second hand off Trademe. After sea trials cannot get the readings from the transducer mode. Readings from the simulator mode works okay. Have also had the wiring and installation check by local mechanical workshop
    Habit-Forming:
    New Friend:
  • 61 Answers
Change your transducer.
Posted on Feb 13, 2018
    Top Expert:
  • Humminbird Master
  • 52,785 Answers
The unit may be defective.
Posted on Feb 12, 2018
SOURCE:
  • 5 Answers
SOURCE: Raymarine St40 trouble
50/200 combination will work fine but 170/200 may be a little close in frequency and give you some trouble. "May be OK" doesn't leave me with a lot of confidence.
Posted on Jul 24, 2008
marked
  • 6487 Answers
SOURCE: reset motherboard bios
Both solution are correct in removing BIOS password, but sometimes removing the jumper when the computer is off wont remove the BIOS password while removing the jumper while the computer is on is definitely fine and 100% it will remove the bios password just like Voodoomox has said if you haven't tried it Tbirdfan1 you can do it in actual to prove that it wont damage the computer, After the BIOS password was remove select CDROM as the primary boot device then save the change the computer will reboot put the Opearting system installation CD then continue formatting and installing the system...
Hope that helps........
Posted on Aug 10, 2008
ward_knutson
  • 64 Answers
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
Posted on Nov 26, 2008
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Posted on Apr 30, 2009
  • 20 Answers
SOURCE: Harley Heated Hand Grips not working
The harley heated handgrips are notorious for failing.  Some people have reported finding a loose connection on the ground wire, like they did not crimp the terminal on the end of the wire at the factory.  If they are wired externally of the bars (almost impossible to wire those any other way) then it should be easy to follow the wire down to inside the headlight bucket or in the nacelle or dash, (depending on what model bike) and check the connections.  If both grips quit at the same time then it's probably wiring.  If one quit first, then it may be the grip itself.
If you need to replace them, I would highly recommend not buying the HD brand anymore, and instead choose Polly grip heaters.  They are made for snowmobiles and have a long list of benefits over the HD type: - fits internally in the bar end, so you can use any grips you want - cost $35!!  compared to $250 for HD - easy to install
I have installed over 7 sets in my friends bikes and not one single failure.
Posted on May 26, 2009
Find manual for humminbird Wide W, serial#6376462
Here is a helpful link for the Humminbird manuals.
http://www.humminbird.com/support/ProductManuals.aspx
Aug 30, 2011 | Humminbird Wide Side Trolling Motor...
Depth and speed are reading accurately however the sonar is skipping meaning it reads for a couple of seconds then blank for a few seconds. No visible nicks in the transducer cable everything is secure. ...
My name is Mike. I understand your problem. What I am doing to help you the best I can, is giving you the manual to download in PDF as well as a support number and other information to help you out. Also giving you my direct page to my Services I offer. Thanks SO Much , Mike.
http://store.humminbird.com/media/document/587_597_HD_DI_Manual.pdf
http://store.humminbird.com/products/399598/587ci_HD_Combo
MY PERSONAL MARKET PLACE SERVICES I OFFER
http://beta.fixya.com/users/mc1beanThank You, Again. Please rate my solution for my free help and some nice comments back would be grateful. God Bless, Mike
Jun 06, 2011 | Humminbird 2009 587ci Gps/fishfinder...
Have a hummingbird chartplotter and would like to use the chip in my pc what program would i have to have to run this
This kind of depends on what the SD card holds. If it is a blank card that you have saved sounder information (readings) onto then you will need to hit the Humminbird website and register your product. You can then download the Humminbird PC software to "replay" your sounding recordings. If it's an SD card that you bought for lake depths or gps then check with the manufactures website to see if they offer software to read the card on a pc.
visit http://www.humminbird.com/support/ and log into the Product Update section to download the most recent version of Humminbird PC
Dec 16, 2009 | Computers & Internet
I have an expired version of microsoft office 2007 i'll be grateful if you help me
Expired, you mean your computer came with Office 2007 installed?
Please follow these steps and let us know:
1- check your invoice for this computer, does it state Office 2007 60/90 trial -or- does it state Office 2007 installed at all
2- check your packaging, if an Office 2007 CD is included in your package, read where the license is listed and check if it says 30 or 60 or 90 day trial on it anywhere.
The above steps will confirm that your copy is not the full version that was installed and it only came pre-installed as a trial (try, then buy period).
If you indeed purchased the full version and paid the couple hundred dollars for it, contact where you purchased your computer from immediately and get them to send you the actual CD that should've come in your package for your licensed copy of Office 2007.
And please, if they suggest that they can just give you the license over the phone, don't go for it. Have them send you the CD with the license typed on it. Should your computer die -or- you should need to reload your computer in the future, you will have no CD to reload from.
Let us know which of the 2 it is. :)
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
Manuel for trn 480
It's a difficult one to find, but Humminbird should have one. Contact them by clicking here and filling out the request.
Jun 14, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Humminbird 7300211 speed unit
Hi!
Installation of the speed/temp wheel is quite easy, here's a manual:
SW Speed & Temp
The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes.
Best of luck!
Mike
Apr 30, 2009 | Humminbird 7300211 SW Speed Sensor GPS...
I need a manual for humminbird wide 100 fish finder
Aug 06, 2008 | Boating
Boating Logo
181 people viewed this question
Top Humminbird Boating Experts
fordexpert
Bill Eager
Mike
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
