SOURCE: Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
SOURCE: I can't raise the bobbin thread. The needle raises before the bobbin thread can 'catch'
readjust the hook to just grab the thread loop as the needle raises it will take a few tries to get the exact setting for the hook (maybe you will see a mark on the hook shaft to show you where the hook's set screw was located before it slipped)
SOURCE: Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
SOURCE: Hi my Singer 7468 machines needle has come out of
I believe if you lower the needle all the way into the case when you adjust that, you should be able to find a happy medium.
