Sharp R-1480 Microwave Oven Logo
Leslie John Posted on Oct 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharpe model R-1480 not heating (it sounds a little louder)
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Oct 31, 2010
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1092721
Points
9665
A loud sort of "groaning" noise and no heat is the sign of a bad magnetron tube. The magnetron is the microwave source, and when they go bad it's usually time to replace the oven. Most microwave repairs, especially a magnetron replacement, should be left to professionals. There are lethal voltages under the cover, and the chance of microwave leakage if the repair isn't done properly. With the price of a replacement tube and labor for the repair, it's often doesn't cost much more (and sometimes even less!) to buy a new oven.
Sorry I can't give you a more positive answer, but thanks for using Fixya!
David Hanks
Level 2:
Scholar:
  • Expert 178 Answers
  • Posted on May 22, 2014
David Hanks
Expert
Level 2:
Scholar:
Answers
178
Questions
0
Helped
49393
Points
314
When a microwave oven stops heating stops heating and starts running with a louder noise or "growling" noise, it is usually a shorted high voltage diode. It can be a shorted magnetron or high voltage transformer but more often than not it is the diode. A transformer will usually short out and start smoking profusely. If the unit makes a loud 'pop' like a firecracker before it quits heating this does indicate the diode because it shorts to ground and discharges the high voltage that was present in the circuit. In any case, you have to have an ohm meter and know how to use it and know what to look for in the high voltage circuit. And you ABSOLUTELY MUST SHORT ACROSS THE HIGH VOLTAGE CAPACITOR BEFORE YOU PROCEED WITH ANY TROUBLE SHOOTING. If you don't know what the different components are you should not be involved in this endeavor unless you are training along side an experienced technician. And whenever you are working in the high voltage section before you are SURE that there is no longer any high voltage present, you must keep one hand in your back pocket to be sure that if you do encounter any high voltage in the circuit, it will not travel across your heart and kill you. This habit has saved my life at least twice in the 30 years I have been working on microwaves......
What is the color of the sharp r-1480?
The Sharp model numbers indicate the cabinet color by the last number in the model number. 0=Black, 1=White and 2= Almond
How do you remove the door panel to install a new door?
If your model is Sharp R-1480, see the service manual here.
You can order Sharp parts from Encompass here.
2helpful
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
How do I remove my undercabinet R-1480 microwave ?
Take this link to Sharp to view a pdf file of install instructions. The model number is different, but most install with the same methods.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Sharp R-1480 replacment door handle
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and even part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
10helpful
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
