SOURCE: pink pixils on light background
When this happens the voltages on some of the circuit boards can be adjusted to claer up this problem. THIS IS NOT some thing a person should do them self, the voltages are dangerous and critical to the operation of the set. "This should only be done by a trained service technician."
SOURCE: 42" LG plasma tv, 4
Probably filter capacitor in power supply if it
exploded should be easy to find may have caused other problems however
could be worth checking
SOURCE: Lg plasma tv screen flickerin
HelloThe problem shows the refresh rate. Quite propably that you are seeing the much slower beat or heterodyne. Often caused by artificial ambient lighting like florescent tubes or faulty dimmers on halogen's etc causing the beat with plasma screens.
Otherwise you need to check power supply
SOURCE: 42 inch LG plasma tv will turn on green led will flash 3 times and then turn off
Check and replace its main digital board. after replacement, somde adjustments have to be done, and you have to enter its service mode option to do it. Really it is a skilled work, that a customer who has no idea in electronics can do.
