Posted on Oct 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to print in b & w only, can I do this w/o having a colour cartridge in the printer?
Guy Sutton
Level 2:
Scholar:
  • Expert 192 Answers
  • Posted on Oct 30, 2010
Guy Sutton
Expert
Level 2:
Scholar:
Answers
192
Questions
Helped
42456
Points
391
You sure can. When you go to FILE////PRINT//// the application box will open up.... Click on the PROPERTIES button on the right hand side in the box that opened, then select the PRINTING SHORTCUTS and select the FAST DRAFT option at the near bottom, also to save MORE ink, go to the COLOR tab on the same box, when it comes up, select PRINT IN GRAYSCALE and also select BLACK INK ONLY...... This is the BEST way to save ink, but, for a finer/cripser look, click on the FINE BLACK..... Good luck and PLEASE let me know if you need more help, always glad to assist!!! By the way, THANKS for using FixYa, tell a friend! Guy :) Have an awesome weekend....
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Coming up with right hand cartridge incorrect it a nearly new cartridge have unpluged and left in for 30 seconds still the same have cleaned the contacts. It printed two sheets then said that it was using...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
2answers
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
2answers
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
2answers
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
2helpful
2answers
HP psc 2110xi color printing problem
The printer head may need to be cleaned. You can buy a cleaning kit for the head.
I have a laptop connected to my HP 5740 & it use to print my PDF's with no problem. Then all of a sudden it prints the wjole PDF in black. What could be done to fix this?
When was the last time you changed colour cartridge?
Your colour cartridge has probably run out. Once you install new colour cartridge, it should print in colour.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
