SOURCE: m-audio firewire 410 on macbook
Use a 'Y' splitter. Usually from balanced to unbalanced. Also try looking at your device's control panel and see if you can change the channel options from mono to stereo. Beta drivers are for testing purposes, so try the signed driver also.
SOURCE: UNABLE TO INSTALL FIREWIRE 410????
I got the same problem, but cannt find out or google it how to reset the device, found just some scripts, cannt use that, do you have some help?
THANKS
SOURCE: I have a MAUDIO FireWire
i'm very sorry my internet went down and i just got it back up and running
SOURCE: My (M-AUDIO FW 410)drivers had suddenly got kicked
Unfortunately, you may have to upgrade. Depending how old your system is typically you need to upgrade every 3 to 4 years. You might upgrade your RAM. When you turn on your computer wait at least 5 minutes for all your drivers to load. If you open up an application before they load it may cause a conflict and not load all drivers. Make sure your not connected to the Internet. When your connected to the Internet all your programs that are not set up to not look for updates will. You wont even know that their doing this until it's to late. This is what I would do. Go to your system restore and restore to a point that you knew it was working. When you look at your restore options it will give you a list by day what was added. Just look at these day's and try and remember what you installed before this started happening. You're having a conflicting problem. Now we need to find out where. Feel free to contact me with any other questions. Hope this helps.
JimmyC
