LG 50PX5D 50 in. Plasma HDTV Logo
Posted on Oct 30, 2010
My LG LCD TV has trouble turning on. It requires several attempts.
2 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Oct 25, 2010
SOURCE: HAVE LG 42" LCD TV
Yes,it will,eventually will not power the tv up all.U have tools like a soldering iron,desoldering pump or desoldering braids and solders?Can u do basic soldering and understanding basic electronic?The power supply board,that the board,where the power a/c cord plug into it.That the tv power supply board.The power supply board have these dying leaking parts call capacitors.These dying leaking capacitors are alway have bulges up on it tops or puffing up on it tops.These dying capacitors that the cause of the deplaying powering up ur tv.Replaced these dying and leaking capacitors,that are bulging up on it tops or puffing up on it tops.The tv will power up wright away and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 27, 2010
SOURCE: My LG LCD Tv has a starting difficulty it gives a
Failing power supply problem.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
1helpful
Lg 37lc7d is having trouble turning on, it starts then stops, then starts and stops then turns on after a couple of mins what is happening
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Lg 42 LCD tv Works fine for about 10mins the loses input display and tv info goes fuzzy. Sound is ok tho
THERE COULD BE SEVERAL THINGS CAUSING THIS, YOU WILL NEED TO GET A DIAGNOSES BEFORE ATTEMPTING TO REPLACE ANYTHING.
7helpful
2answers
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
2answers
I have an lg 52LG70, 3 years old. recently, after i hit the on button, the tv will come on, but within seconds, fades to black, starting at the corners, moving to the middle. still have audio. a few...
Tv have 2 long LCD inverter boards it probally require replacing.These 2 long LCD inverter boards job are to provided the tv LCD screen panel to have a backlight to the tv LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
2answers
42" Lcd problem
I belive the repair shop might be try to get more money from you
if you enscrew the back of the tv ( with the tv unplugged ) look for a flat wirestrip thats not connected
I think they either forgot to plug in that video wire or they did it to make money from you
did it work fine before the dim screen or did it come back to you like that?
TV will not turn on
the exact same thing happened to me but there is no red light when the TV is plugged sould i replace it?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
