HTC Touch Diamond Smartphone Logo
Posted on Oct 30, 2010
My HTC touch diamond - wont start, if connected to the charger it only makes "click" noise ..lights for 1 second, then it "dies" again :(
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
240
Points
I have this kind of problem =( . i have htc touch diamond and when i charge the phone it has 20 % batterylife , the phone is lighting BUT after 6 h i look at the battery life after charging and it has still 20% of 100 % battery life
so it has the chargin light but the battery Wont charge =(
My HTC Touch Diamond will not turn on. I charged it overnight and it wouldn't turn on this morning. I have tried removing the battery and reseting the phone. It was working fine the day before. When I plug...
Try to narrow down where the problem lies. Try charging from another outlet to make sure it's not a problem with that outlet. Then try a different charger or battery.
tip
How to view DVD movie on HTC Touch HD/Pro/Diamond/3G/Cruise
Quoted from: http://www.daniusoft.com/convertdvd/dvd-to-htc-touch.html
HTC is taking the lead in Windows Mobile and Android smartphones on Windows and Google’s platform. However, the video playback seems to be overlooked by HTC, so this tutorial will show you how to convert DVD to HTC Touch, Touch2, HD, HD2, Pro2, Pro, 3G, Diamond2, Cruise.
Whether you are already HTC Touch owners, or you are HTC Touch enthusiasts, willing be of the next HTC Touch holder, you would definitely not wanna miss the opportunity to play DVD movies on HTC Touch, making HTC phone a more powerful integrated media player.
Generally speaking, DVD purchased or rented always have copyright protections, So if you want to convert DVD to HTC, first you need a Best DVD Ripper to remove all the restrictions of DVD: CSS, Region, RCE, Sony ARccOS, PuppetLock, Daniusoft DVD to HTC touch converter can help you crack DVD protection and convert DVD to HTC Touch compatible video formats.
Free Download Daniusoft Best DVD Ripper for HTC Touch, Touch2, HD, HD2, Pro, Pro2, 3G, Diamond2, Cruise.
Recommended video formats for converting DVD to HTC Touch
MP4 file would be the best video formats for HTC Touch compared to 3GP, WMV with better video quality. HTC Touch HD plays 800*448 fps, h.264, 24fps, 1.2 mbps files smoothly.
How to convert DVD to HTC Touch HD/Pro/Diamond/3G/Cruise
Since you don’t wanna miss you chance to watch your favorite movies such as Disney movie Up on HTC Touch, a DVD to HTC Touch converter is in need to convert DVD to HTC Touch for your enjoying.
Daniusoft dvd ripper is such a DVD to HTC Touch converter which can crack DVD protection, convert DVD to mp4 or other HTC Touch compatible video formats.
To play DVD movies on HTC Touch, what you need to do is only three steps:
Step 1: Load DVD files
Click Load DVD to load DVD Rom, DVD folders, ISO files and IFO files respectively.
Step 2: Customize output settings
Click Settings in the output settings area, you are allowed to customize the output parameters and specify output format and folder.
Step3: Start to convert DVD to HTC Touch
Click "Start" to start conversion. All the tasks of conversion will be finished at fast speed and high output quality.
This Daniusoft DVD Ripper can not only convert DVD to HTC Touch, Touch2, HD, HD2, Pro, Pro2, 3G, Diamond2, Cruise, it could also convert DVD to HTC Hero, Dream, Tattoo, Magic, Viva.
on Mar 31, 2010 • Cell Phones
3helpful
2answers
How to snchronize htc diamond touch with windows 7?
First, download Windows Mobile Device Center from Microsoft ( Google it) and install it in Windows 7
Secondly, plug the HTC diamond touch with USB connection and wait for the windows update search the driver of HTC Diamond Touch.(This will take a while)
Then It will ready to go.
Hope this help you.
How come my htc diamond is not charging
Either you charger is dead(internally)or replace the battery.Sometimes the cords connected to the charger is cut off(Unseen but appears when ran thru a DMM analyser).If the charger works with other units the charging input is internally loose and needs opening by someone who knows the insides of a really costly cellphone.
My unblocked htc touch diamond wont recognise my 02
that is the set frequency problem . your connection will not supported your handset.
1helpful
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
1helpful
My HTC Diamond will not charge!!
Yes, it just happened to mine. I've had mine since Oct. 2008 (so almost 7 months) and last week I noticed it was running out of battery mid-day even though I barely used it.
Always make sure you are closing all running programs throughout the day by clicking on the top right corner (the symbol with 3 horizontal lines and a downwards arrow, then clicking the X).
Make sure you test it out with a different charger, not just different electrical outlets. Or, at least check to see if the "HTC" logo on the charger is lit. If it is, the charger is fine and the problem is most likely with the phone itself.
If so, take it into the carrier you purchased it from (ie Sprint) and have them take a look at it. It is most likely a problem with the port on the bottom of the phone. Good luck.
1helpful
Htc touch diamond black pc suite
when u plug u r USB cable to u r PC it ask for two options
1. Active Sync
2. internal storage
select second option and drag and drop what ever u intrest
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
