Open the hood, and you'll have to reach around under/behind the headlight. Feel for the electrical cable going to the bulb. It should attach to the bulb with a round plastic hub that you can rotate to detatch and remove the bulb from inside the engine compartment. It's very tricky if you have big hands, and there's really no secret to doing it, just take your time and don't get frustrated if it takes a while.
Remember, when you can feel (it's really hard to see) the round plastic hub the wires connect to, gently but firmly rotate the hub until it detaches, then carefully pull the bulb out. Remove the dead bulb, insert the new bulb, and then gently reverse the process, being very careful when inserting the hub and bulb back into the headlight. Then rotate it the other way around and close the hood - you're done!
