Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in
Part Store Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
I have same problem. I need LCX043ATB5 but this is installed in the optical unit of a KDF-55WF655. Sony only sells full optical assembly,
