You need to buy a handle puller to remove the handles so you can change the washers.
Testimonial: "I was hoping that that was not the case, but thanks very much for confirming it."
hI, YOU ARE GOING TO NEED A TOOL CALLED HANDLE PULLER IN ORDER TO REMOVE THE HANDLES FOR YOUR FAUCET, IT HAS TWO SIDES THAT SLIP UNDER THE HANDLE ON BOTH SIDES AND A PEICE THAT GOES INTO THE CENTER WHERE THE SCREW GOES. AND AFTER THE SCREW IS REMOVED AND YOU PUT THE TOOL IN PLACE AS YOU TIGHTEN IT , IT PULLES THE HANDE UPWARD REMOVEING IT WITH OUT SCRATCHING IT UNLIKE A PAIR OF PLIARS WOULD. i HOPE THIS HELPS YOU CAN BY THEM AT fERGUSON pLUMBING SUPPLY HOUSE FOR AROUND $15.00 DOLLARS.......hUCK
