My HP 2610xi ran out of ink; so I changed both cartridges - Black (HP 94) and Color (first tried with HP 95 and then with HP 97). No issues with the Black Cartridge but the printer refuses to recognize the color cartridge - neither of them; keep complaining to check the cartridge.
I tried, re-inserting, wiping the contacts, unplugging the printer for a hard boot - all for no avail!
It won't allow me to even bypass the error and work with just the black cartridge!
Can you please help?
Really appreciate it,
- Tapas
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Check color cartridge error message keeps coming up. I changed out a nearly new color cartridge to see if that was the issue, however the error message continues.
THIS IS REALLY UNBELIEVABLE THE DAM HP 97 DOESNT WORK AND THERE APPEARS TO BE NO SOLUTION.
- Moe
Have the same problem when i change the color cartridge (Europe HP 344
the same message " check color cartridge" come on the display and can not print what is the solution ???
