It could be a bent selector shaft,has the chain fallen off before it was parked up ? If not it could be a selector shaft pawl problem inside the engine or a bent selector fork.
There should be a thumb release on the shaft at the handle end, press with your thumb and then pull back with the other hand on the shaft. If you have a used tube in the gun, it could be that some of the caulk came out the inside of the tube and hardened so that you cannot pull back the shaft, you will now have to cut the tube off with a utility knife to remove the old dried caulk
Assuming that the gun will not jam with nails removed and the driver returns to top of cylinder when fired without nails. If the driver is bent the nailer will jam without nails. Jamming is usualy caused by bent driver, driver tip worn (not square), or wrong nails. If the driver is not bent and the tip is square, suspect wrong nails. Easy test. Place a strip of nails on outside of rails with the nail heads aligned with top of rail. Move the strip of nails toward the nose if gun. With the heads aligned with the top of the rail, the first nail should align with the path of the driver. If the first nail does not align with the path of the driver and the head is angled slightly away from the path of the driver, the driver may strike the shaft of the first nail pushing the nails back into the rails. If the head of the first nail is forward with the nail shaft angled back away, the nail will flip causing jam. The first nail should align with the path of the driver to prevent jam. It is difficult to find perfectly made nails that align correctly. But certainly check the nails with test mentioned above with every new box for accuracy. You might find that you will need to change brands to get a good fit. Good luck.
If your pulley shaft is bent the only thing you can do is replace it, I have not seen a shaft that could be repaired just replaced and usually that means the pulley as well. You will need to contact the dealer. if you need further help please contact me.
thank you
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Most John Deere dealers have a jig that the engine itself can be bolted onto and repair crank.Our dealership flat rates this repair at 2 hours but will vary among shops.
Not a good idea to try to straighten the shaft. Once done, if effective, you have bent the shaft twice. The factory asks you to not try to straighten a crankshaft. Some do it, however risky it is. Mikey
