Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
Posted on Jun 10, 2008
HITACHI 57F510 57 IN REAR ......... PROBLEM
TV TURNS ON BUT NO PICTURE OR SOUND COMES OUT . THIS HAPPEND OUT OF NO WHERE NO SIGNS OF PROBLEM. WHAT COULD IT BE?
  • dwh27 Oct 04, 2008
    I have the same problem. When turning on the TV, I know it has power because all I see is that the little red power light is glowing red. No picture or sound!
  • virostek22 Feb 16, 2009
    a week or so ago the screen turned green then in a little while it went back to normal then it turned red a few days ago but in a minute or so was okay, today the screen turned black and didn't change, the sound still works.
A
Anonymous
Does the menu come up if so you need to change you inputs.
Hi there my hitachi 55"
On SDR PWBs. some times, you may be able to see a hole or damage signs on them, or not. The continuity
test on each IC will confirm if there are any shorted Ics, even when there are no external signs of damage.
12helpful
2answers
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Hitachi model 43uwx10b comes but no sound or
sounds like one of the transistors attached to a heat sink shorted out.
you will need to test each one with the tv unplugged.
set the digital meter on diode.
it`s not easy to explain the rest, sorry.
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
2answers
Everything work's on the tv there's no visible picture
the same thing happend to my 62 in you most likely need to buy a new convergence board which is in the $3000-$5000 price range so you would be better off buying a new tv thats what i did that is the biggest flaw in projection tvs
Tv problem
Yes, my tv turns on but no picture it was going off the you have to unplug for a second are to then plug it back up. But now it turns on but I don't have know sound are picture.
3answers
Will not turn on/ black screen
My Hitachi Tv 43fwx20b turn on but not have sound and picture
3answers
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
