Sorry, tried to send a comment but I sent you a rating instead. What is a hard reset? if you mean turning off the power for 24 hours then yes,
Turning it for 24 hours by removing the pulg from the wall socket.
then after 24 hours try to press start(or any equivalent button to start the unit)
u must not see any kind of movement in unit since u r not connected to power.
this is done to drive off the unnecessary power from the unit that we dont need.
now you are done.
if everything goes fine you are done.
Winsock error 10054 is "Connection reset by peer", or "An existing connection was forcibly closed by the remote host". The error means exactly what it says - the remote host closed the connection unexpectedly. This happens when a connection is aborted, and there is no tcp disconnection handshake (fin, fin ack, ack) , but instead a rst (reset) flag is sent. A reset flag aborts the connection, and can be sent when:
- The device is suddenly stopped, rebooted, or loses its network connection.
- The device uses a "hard close". With IP*Works! a hard close never occurs unless you specifically set the Linger property (IPPort, IPDaemon) to false.
- A "half-open connection" state occurs. That is, when one device not been receiving acknowledgements of the data it has sent, or it receives acknowledgement for an unrecognized sequence or ack number, it will send a rst flag to reset the connection. This particular case could have a variety of its own causes, such as misconfigured proxy/firewall or network quality issues resulting in too many dropped packets.
